Not sure if it was mentioned previously - posi, G80 is an option, not every SS had factory posi.
Sweet, thanks! I was hoping that was gonna be the response. No offense to auburn, but my dad swears by eaton diffs. Him being a veteran diesel mechanic for over 4 decades i trust his judgement, usually that is considering the diffs he works with are as big as our factory wheels lol!I like the Eaton better since you can change the clutch packs and you can get different clutch packs made with different materials and springs with higher pressures...
I wouldn't call myself an expert on rear diffs so I didn't chime in until now. I can tell you that we put a new Eaton posi in my brother's Z28. The new units have carbon fiber clutches that should last much better than the old school fiber clutches. If I ever replace the govlock in my 08 Sierra, it will be with an Eaton Posi.Sweet, thanks! I was hoping that was gonna be the response. No offense to auburn, but my dad swears by eaton diffs. Him being a veteran diesel mechanic for over 4 decades i trust his judgement, usually that is considering the diffs he works with are as big as our factory wheels lol!
how could a salesman let a customer walk in, order a Monte Carlo SS and not talk him into a posi for the performance vehicle. .....
Since this is a topic of discussion...i have a question.
I will be rebuilding the 8.5" in my cutlass next year since i have some popping and nasty noises coming from when i drove on a bent axle when i first got the rearend. I plan on putting all new guts in it.
Most likely some moser 28 or 30 spline axles, new richmond 3.73 that i have waiting, and new install kit obviously.
Back to the question, would an Auburn posi be better than the Eaton???? Both are priced about the same, this is just an area i lack some knowledge on.
Any advice is appreciated!
Thanks for the heads up on getting the stuff from quicks! Always thought about swapping to a 9", but with the 8.5's getting harder to find I'd rather rebuild it and keep it under the car....keeps it GM too.Rebuilding the posi and new axles will is going to run in the $500+ range. You can buy a new one from Quicks with axles and bearings for around $700ish. And at that point you can grab an 8.6 31 spline posi unit (direct replacement for newer full size truck) and axles for the same price.
I do agree with UNGN that a set of Moser 28 spline axles will with withstand a 10 second car, but my opinion is if you're going to upgrade, then why not get the best bang for your buck. Especially considering you're planning to add some boost in the future.
And FWIW, I thought all of the factory clutch sty;e 7.5's and 8.5's were Eatons made for GM. I've used Eaton clutches in a GM unit???? And I've never seen an Auburn as original equipment - I guess I earn something new everyday.
Well, 2 out of 3 SS's that I checked had an open diff. C'mon, does 180 HP justify the need for posi? (LOL)
