David Williamson said:Quick question.
How hard is it to loosen the y-pipe I see there are two screws on each end. Could I just loosen them and take the ratchet out and tighten it back up, or will it be extremely hard to put it back up there?
the other side of the y pipe is still in place so the side you loosen won't go anywhere, if you pull down on the pipe you loosened so you should be able to get your ratchet out. And like Bonnewagon suggested spray them good with some release oil
