Thanks Jack, Danny, and Jared for the responses. Danny, I will probably section a Regal headliner board, to fit the Century, as I can't find anything, new or used. Then upholster it myself. It will probably be one of the last things I do, since you don't see it much, and it will give me more time to source one, if it pops up..
So lets talk transmissions, guys. I can go either way 350 / 400 /200-4r. I have used a 350 behind several hotrods in the past, ranging from 350-500hp, so I know with the availability of hi-po parts, this transmission can survive behind a BBB. I do know that it's the least recommended for this application, it's also the lightest, and uses the least amount of horsepower to operate.
With that being said, I already have a console w/ 4 speed top plate ( that can be changed to 3 speed ). I already have a B&M stealth shifter with both 3 & 4 speed gates. The 4 speed is already installed.
The car itself has a 3 speed shifter on the column. I just thought it would be cool to keep it there, and the 350 would drop right in ( things I need to consider $$$ for this project ). But I know I should go with a 200r4. And guess what?? The guy I bought the motor from has a BOP 200-4r that I can buy ( complete w/converter that I would not use ) for $125. It's very clean, and has been kept inside.
Pros- its got the converter still attached so I would guess the input shaft is not rusted. Pan and lock up pigtail are intact, Still a bolt in. I have a GN friend that is a transmission builder by trade.
Cons- more expensive to build, more expensive converter, having to purchase, and install lock up solenoid switch, new crossmember, and new floor shift column.
Solution = buy both TH350 & 200-4r transmission cores while they are available, and cheap. Both = $185. Figure it out after speaking with my transmission guy.
ALL comments, concerns, and/or advice is appreciated.
