This sucks. No chance it's not the flexplate and the sound is transmitting through the crank?
I briefly thought of that but the only time I ever had a flexplate issue it was a distinct knock from the back of the engine that sounded more like a rod knock. Anything's worth checking out at this point, though. Obviously it's not driveshaft or differential related.This sucks. No chance it's not the flexplate and the sound is transmitting through the crank?
Don't do it! Reseach has concluded "LS" is 40% on its way to be "LoSer". Mathematically, there's no way around it. 🙂
Well, wait. LS has been so overplayed it sort of is considered "old school" today. But you have to wait a couple of months. LS swaps are only allowed in the month of "Meh."
Mr. Sony had a wobbling flex plate that made a shrieking noise. That's the only reason I mentioned it.I briefly thought of that but the only time I ever had a flexplate issue it was a distinct knock from the back of the engine that sounded more like a rod knock. Anything's worth checking out at this point, though. Obviously it's not driveshaft or differential related.
Well, then that is a possibility, then. Luckily it's not a common enough issue where people can instantly pinpoint that.Mr. Sony had a wobbling flex plate that made a shrieking noise. That's the only reason I mentioned it.
Hey, no political posts! Oh, sorry, my bad. Thought it was the current occupant. 🙂 It's only Walter. Put whiter hair on him...spittin' image.![]()
Thanks, Walter.
You're missing your posi lube additive. Didn't whoever rebuild that differential already soak those clutches?
@Streetbu , I think he means that varying rpm has no effect on when the noise shows up or goes away if I read it right.
Taking off the belts and it's still doing it rules out the water pump. That would have been my next guess.
Is the oil clean and not metalflakey?
How long has it been since rebuild? Or timing chain replacement? Using a cam button?
I would highly suspect the balancer. If it's stock, is it moving or wobbling at all? How's the crank pulley? Still solid and not wobbly?
So the noise doesn't change with engine rpm?
I know audio is hard to capture perfectly but maybe take a video of her running so we can speculate a little.
That sound? It's the car telling you it's time for an LS-swap.
Have you got the engine up to temp lately? How many miles has it seen? Spinning the seal is possible but unlikely. If it was it should be leaking.
It's a late 80's center bolt valve cover SBC correct? Roller/Flat tappet?
