Anybody remember this car?
Went over to the neighbor’s garage this morning and pulled the cover off it. Removed all the strategically placed dryer sheets to keep the rodents out, then drug my air hose across the alley and filled up the flat left front tire. Jumped in, pumped the pedal four times, then cautiously hit the key. It caught on the 4th revolution and sprang to life!
After letting it warm up sufficiently, I pulled it out and checked and adjusted the pressures in the other 3 tires. Had to dust it off a little bit even though it was covered, but that ain’t too bad for sitting in cold storage for 8 months.
I’ll take it.
43 likes, 10 comments - rktpwrd5 on June 2, 2022
www.instagram.com
After emptying out the trunk and giving it a thorough visual inspection, I took it over to the local auto parts place and grabbed 6 qts of Lucas Hot Rod 10W 40 oil and an extra capacity Wix filter. Damn I forgot how nice it drives.
The remainder of the afternoon was spent doing the oil change, tweaking the carb a bit, and generally fussing around with it. Not much to do though, as it seems to be running extremely well.
Tomorrow I have a set of the thick fender support braces that I want to swap out, then I was thinking about getting the rear tires changed as well as I have a relatively long distance drive to a show I want to go to on Saturday. Don’t particularly need a flat out in the middle of the boonies.
Which brings me to a question for y’all, and a bit of a dilemma:
Being off work because of my knee this week, my company has taken my work truck in for a few repairs. I have a spare set of mint matching rear BFG tires identical to the ones that are already on the car, and normally I would pull the wheels off and just throw them and the replacement tires in the truck to take down to the tire shop.
But now having no truck, if I want the tires swapped it means that I’d have to bring the car and the tires down and trust some greasy tire monkey with the car to pull the rear wheels off and change them out.
What do you guys think? Should I trust them with this simple mundane task after all the hard work and effort I’ve put into restoring the car? I’m just nervous about anyone doing anything on the car because I know they won’t have the same respect for it as we all would. I’m just picturing impact guns on my chrome lug nuts and scarred up wheels with hammered on weights.
Whadda y’all think??
D.
