well here i am at the school of hard knocks again. this time i'll ask the experts, you guys. i'm putting my radiator system (81 malibu) back the way the factory had it. got a new clutch and 18 inch 7 blade fan and started to install the shroud. as you can see in the pics the shroud is a little short on fitment. looks like the shroud should fit a smaller radiator. i did not notice the fitment before the change. po just bolted it down with the rubber not fitting very well on top of the radiator. been looking for a top part of the shroud that fits my larger radiator but i'm beginning to think there was not a bigger shroud. looks like this one would fit a 26 1/2 core and not my 28 1/2 core. i have used the clutch fan system before and had very good luck with it. had a dual electric system on the last three years and had" i hope it does not over heat" luck in the past. want to solve the "in town in stop and go" because it looked like it could heat up so i got out of town fast. can't enjoy it that way. i have had to make a few changes in the past to a few shrouds on some of my hotrods but would like to avoid that. btw its a crate 350 and was an original small block (the smallest one) from factory thanks, Denny
