Radiator
Supercharged111
4,956
7,760
Colorado Springs, CO
I just think it's a radiator problem
That could be, but you need to make sure the air isn't going around the radiator. Just cruising down the highway a stock radiator should be adequate.
8,831
7,790
What are the specs on your 350?
Rocket350olds
Jun 6, 2020
91
48
72 olds 350 30over 9.5to1 comp cam 7a heads switched to adjustable rocker arms around 375hp
8,831
7,790
A new rad sounds like a good investment and probably necessary with higher compression. You want a minimum 2 core with 1" tubes for a replacement.
8,831
7,790
Hopefully it cools better than the Champion 3 core did for my 403 in my 88. It depends on fins per inch etc. That 800 hp rating is wildly optimistic. A large 2 core will out cool a 3 core and usually a 4 core. Another thing that helped my car is the GN rad surround flaps. They basically make the air go through the rad, not around.
Rocket350olds
Jun 6, 2020
91
48
Dp you think a 2 core with 1 1/4 tubes would be best and where did you get your radiator surround flaps?
8,831
7,790
