OK so I’m entirely off the ball on those brakes. That’s a Right Stuff Detailing brake kit with Seville calipers.Hmm... those calipers look like SN95 calipers, but I’ve only seen those used with a single piece, non-vented rotor. I’ll look at some of the Ford brake setups and get back to you.
If you still haven’t gotten seam sealer, a good one to get is Lord Corp.’s Fusor 123EZ. The stuff is an epoxy sealer and will flex with the car without cracking. It also builds real well so you can use it to fill in the large gaps the factory left, like between the cowl and A-pillar where they both meet the firewall.
This thread seriously makes me want to cut up and fix my floor pans the right way, that’s some amazing work!
Thanks I really appreciate the kind words(and memes). It just shows what you can do with the right mindset, tools(and a parts car). Plus all the info filled build threads on here you can do almost anything. I bought some seam sealer off jegs 7 bucks a tube around Christmas.Hmm... those calipers look like SN95 calipers, but I’ve only seen those used with a single piece, non-vented rotor. I’ll look at some of the Ford brake setups and get back to you.
The 1k stuff will do the trick, but I’d use it in areas that see the least amount of water and I’d epoxy primer over both types of sealer.Thanks I really appreciate the kind words(and memes). It just shows what you can do with the right mindset, tools(and a parts car). Plus all the info filled build threads on here you can do almost anything. I bought some seam sealer off jegs 7 bucks a tube around Christmas. View attachment 147325
I think I bought 7 tubes. Im not sold on using it yet but I cant afford to do the entire car in 2 part seam sealer. I was gonna use 2k on the drip rails, trunk to qtr seams and others that you see and the cheap stuff on the floor etc. Those brakes seem to be in a bind ,definitely questionable installation. Thanks for the link. From what I've read the sn95s are the way to go. Plus there's 100s wrecked in the picapart.
Your killing it man. That's a lot of drudgery work and it's looking really good. Keep going, you're getting closer!
Stay the course brother, your plan is sound. As said, it’s monotonous drudgery work but it’ll pay off in the end. It’s coming along nicely, keep at it!
Well you probably scared me enough with the word "lift". It'll probably take longer to dig out the remaining primer as it did to strip the paint off everything but im leaning towards takin it off. Thanks for the advice. Btw you could've left your rant about the brakes up. I appreciate your opinion. It helps to make informed decisions. Plus it was kinda funny.That’s some good work on that floor.
Go ahead and take the rest of that factory primer off on the backseat area, you’ve already got most of it off. If you’re painting it with epoxy, it could start to lift down the road since it’s lacquer; judging from the white paint in the interior.
