I finally made it back to the junkyard this week. I got my last few fuel line quick connects. The straight stainless ended up being the hardest to find. 2002 V6 camaro has stainless straight fittings. So the fuel lines are in good enough to put the body back on. I clearanced the rear crossmember to make sure it doesn't get pinched.
I couldn't find a 90* brake fitting so I tried to make the double bend again. Failed. So I came up with my own bracket. The astro brake hose is longer so it works. The suspension is so stretched out the springs almost fall out and there's still slack in the hose. Then I proceeded to make a perfect flare, and then kink the line.
I had enough 1/4" line left over to remake the line but I was pissed. The bracket is just a piece of 1/8" steel. Used a step bit to make the hole the right size and a drill bit to mimic the locking portion. Its in there tight, also you gotta mount it as low in the frame hole as possible so the hose isn't short.
The bottom of my pass A pillar was rotted, likely caused by that damn foam. I cut the patch from my parts car before I gave it away. I cut out the bad, pulled some of the foam out and sand blasted it the best I could. Dumped rustoleum in there when it was 50*F out so hopefully it'll help it from happening again. I think I can get the inner frame coating nozzle in there when it's off the "Rotisserie".
I just used the bottom of the patch panel and fit it in the hole.
Here it is welded up and flattened out.
The pass side A pillar had a little hole in it. I pulled out what foam I could and sprayed rustoleum in the hole.
Then I just filled the hole with weld and knocked it down with a roloc.
Boy can I relate to misplacing tools I just had. I thought it was just part of getting old. Thanx . I remember back when you started your project with little/to no experience. I’m impressed with not only the fact you’ve stuck with it, but the quality work you’ve been doing. Most would have given up long ago. Keep it up.
I think the more frustrated I get, the more lost whatever I'm looking for becomes. Plus my garage is a cluttered mess right now. I cant walk through without touching the car,frame,or walls. I appreciate the kind words and help you've provided.
