Well unfortunately SSM is backed up until late October and everyone he knew local to me was also.They advised me to take the 8.8 to moser. Its about 2 hrs from me. Ill probably call them this week to see if they can fit it in or just buy some 28 spline 5x4.75 axles from them and save money. Still undecided.
Meanwhile I've been swamped with work/kids. I've had to take up stripping nights and weekends to try and get the car done. On the roof I removed the paint leftover from the paint stripper with a clean n strip wheel. Very light pressure and constant movement.Then I block sanded the green primer off. I was taking no chances. I felt the roof skin move a tiny bit so I switched to hand sanding with my long block and 80-grit.
The passenger qtr
Passenger rocker.
Both wheelhouses.
While stripping the wheelhouse I realized I screwed up where I put the fuel filter. Its about 1" too thick to fit in between the rocker and floorpan. It looks like I'll have to move the filter back 6" to make it fit.
I also got the Fenders stripped. No rust, 1 dent on the top of driver. The pass antenna is fully too.
Pretty much everything needs sanded with 80 grit. I have a few high spots on the driver qtr and 1 dent on pass rocker to straighten before epoxy. The way I understand, I have 7 days from the time the epoxy goes on to do the filler/ 1st rd block sanding. Then I can spot epoxy over the spots that go to bare metal and then spray the 2k. I'm shooting for mid may hopefully.
While stripping the car I've noticed this all over the place. Checked paint and surface rust deep under what looks like good paint. I swear these cars came factory with rust. So I'm guessing thats why you have to strip the paint to bare metal.
And if your stripping panels try to get epoxy on it fast or this'll happen.
