Serpentine belt conversion
I'm part way into the swap right now. Through an ad on the internet, I managed to snag the complete setup from an '88 Firebird, for a good price. I'm trying to get all of the brackets and parts cleaned up now. I can't tell you for sure just yet, but it looks like it should work. The problem that I have right now is that I'm trying to swap from an engine driven fan to an electric cooling fan, I need to find parts from a Buick GN or turbo Regal (1986 or 1987), and I haven't found all of the correct parts that I need just yet.
Don't use the steel shoehorn setup from the late '80s full size trucks, puts the steering pump pulley too close to the steering box. You can use one from a 4.3-equipped S-Series truck/suv as well.
That might be ok... is the bracket all steel? That's the one I had fitment issues with. The round-cover steering box cleared, but the 4-bolt one didn't. Needed slight clearancing and it ran ok while I had it on there, but clearance was so tight I couldn't even get the serpentine belt off :roll:
Reactions: Griffin84ss
I put the smaller pulley on but that wasn't enough... First off I had to put the smaller pulley on, then get washers to push it farther back on the pump shaft because the pully installer installs the pulley to where it is flush with the pump shaft, I needed to go on farther because the smaller (91 Beretta) pulley wasn't as deep as the stock (88 GMC) one was. After getting it back to where it lines up with the belt I installed the pump back on the car. It still just barely hit. So I had to do what I didn't want to do and shim the motor mount on the driver side. I shimmed it about 3/8". I also grinded a side off the bolt on the steering box for just a bit more space.
I don't like having the mount shimmed but it will work for now. I will definately be looking at fabricating something to move the pump up and maybe in.
I will get pics tomorrow, or well later today.
I'd like to know if there is an all inclusive (or mostly inclusive) how to on this. I have the brackets and pulleys that I can use with a TPI motor, got a reverse rotation water pump and alternator for a 91 Camaro. I also have already installed a dual fan setup and radiator from a late 80's IROC. What I need to know is will my power steering that is on the car now work? A/C hose setups and r-12 to r-134 conversion. I work at AutoZone so I can get the parts. Any info will be appreciated.
I believe you'll have steering box clearance with the F-Body setup, the water pump will be fine, the reverse rotation pump was used on several different vehicles. The alternator you should be able to wire to the brown wire that went to the original alternator.
with doing this conversion like how the ac compressor sits on the driver side will it remain there or does it have to be relocated
Bumping this thread. Anyone that has or is still doing the swap have any information? I'd like to try and tackle this over the winter. Do the S10 accessory brackets need 3 holes on the heads or just 1? And what about AC lines on cars that are keeping the compressor?
Cutlass or Regal V8 A/C lines and condensor is needed, no need to relocate the compressor.
