Non DOD valley cover for a DOD capable block :
This is what is underneath a DOD valley cover:
When the valley cover bolts loosen, then the DOD lifters get activated with LOW oil pressure and the pushrods on those lifters get the ends ground off from them. And the motor looses oil pressure as well. Grinding up pushrods always aids in the usual result of fine particles of metal being sent into the oil pan.
I know alot of us don't have the time or the availability to junkyards, but if you were one to do some investigating of this, head off to the local scrapyard and pull some DOD valley covers and pushrods on high mileage motors and see what you find - it will be obvious after you see 4-5 of these things what the issue is. Of course this not speedy - the intake and related parts have to be removed to access, and both rocker arm assemblies under the valve covers. I'm yet to pull apart a high mileage DOD motor with the 8 DOD pushrods in good (re-usable) condition.
Rt Jam the only maintenance I know of is monitoring your oil pressure. If you see it start dropping then check the valley cover bolt torque as the 1st step. Changing the 8 DOD lifters is a PITA - 'Off with their heads!'
One positive not about changing the lifters is that it's much easier to get out the 3-6 broken exhaust manifold bolts with the heads off 😉
12598832 Gen 4 LS Non AFM DOD Valley Cover With Gasket for 4.8L 5.3L 6.0L 6.2L | eBay
<li> To Dear buyer</li> <li> </li> <li>❤The delivery time (EDT) on the listing is only the estimated delivery time of eBay.</li> <li>❤Please dont worry about the delivery time,usually it only takes 3-7 days to arrive you as we ship the package from US via UPS.</li> <li>❤Any delay, we will send...
www.ebay.com
