Smart Glow Fuses
Ernest
746
1,012
Texas
They have a built in mini L.E.D that lights up after fuse is blown, makes it much easier to find and replace than trying to figure out which one after a main device or accessory stops working... anyone here use them?
Wageslave
1,750
3,341
I have them for my underhood add on fuses. They work pretty good and saved me a little bit of time troubleshooting a stumbling issue when I found a fuel pump fuse blown.
Ernest
746
1,012
Texas
No doubt its a SMD(surface mounted device) L.E.D inside the fuse... those things are tiny.
Rktpwrd
Builder of Cool Shjt
4,171
23,924
Calgary, Alberta, Canada
Gimmick, pass.
ck80
5,743
9,123
Gimmick, pass.
For most things I just kinds know what circuit the blown fuse has to be on based on what doesn't work.
Mixture of age/wisdom or whatever they call it, well, that and driving mostly big dumb vehicles without much for computer ninnies.
Ernest
746
1,012
Texas
These may be gimmicky.... but would prove very helpful, especially if the fuse panel is lit up like christmas tree because you've got major electrical issues. :giggle:
ck80
5,743
9,123
Meh, the fuse block in my c10 is even easier. Still uses glass tube fuses. Look underneath and instantly see everything that is blown at a fraction of the cost.
What was old is new again I guess.
Makes me want to buy some of that paint they use on dot sights or compound bow pins. Go around a car show and put dots on the douchier of guys who have these's fuses that have these then watch them freak out.
Built6spdMCSS
5,804
9,715
Florida Beach
Given electricity takes the path of least resistance, probably a resistor infront of the LED since they don't need much voltage to work. Fuse element intact the current goes that way. When it pops now it's on the LED side.
Ernest
746
1,012
Texas
Built6spdMCSS - Yes.... SMD L.E.D with internal resistor.
CK80 - No matter how much of a douche or you hate the guy for whatever reason, its a general rule amongst men, never mess with another mans vehicle... thats unless he messed with yours first for absolutely no reason, then by all means, retaliate with extreme prejudice.
