Yep, I'd call Lares. They have a pretty good tech support line/chat system. I'm assuming you have the Lares 1282 because there's not many other manufacturers that have the 12.7:1 boxes. God help you if it's Cardone.when I buy something and have an issue with it the first thing I do is to call the vendor.......
I doubt it's air. Air in the box makes it feel jumpy or intermittently rigid. It's also really noisy and you'd see foam in the PS reservoir. I've heard that the the check valve can get damaged during installation or if a piece of old o ring falls down in it while you're installing the lines.I installed the pitman arm incorrectly
That's the reason for my turning being incorrect
I'm concerned about it not bleeding air properly Or that's how it feels. Something is either locked up inside it or it has air trapped
I've since reinstalled the original gear box with no issues
