check your connections on the battery and charge it up and take a look at the connections on the starter
CamaroAdam73 said:I know the connections t othe battery aren't the problem but like i said, the rest of the wiring harness is in really rough shape, and I've got a good feeling that the connection to the starter has something to do with this, but what worrys me is when i turn the key to the on position, my check engine light does not come on anymore, and i don't here the "beeeeep" sound either.
dan2286 said:CamaroAdam73 said:I know the connections t othe battery aren't the problem but like i said, the rest of the wiring harness is in really rough shape, and I've got a good feeling that the connection to the starter has something to do with this, but what worrys me is when i turn the key to the on position, my check engine light does not come on anymore, and i don't here the "beeeeep" sound either.
Check the connection at the starter, it supplies the power to the whole car. If you have a volt meter, it would me much easier to figure out.
CamaroAdam73 said:Actually Custom442, when i took the top of the cap off to plug in the sparkplug wires the ground wire came lose! And it looks like it goes around the screw that holds the top of the cap on, it has a little eye hole at the end, but i'm not 100% sure, and yes it was firing to the right cylinders, i'm going to give it another go today and see if i can get it working right.
CamaroAdam73 said:So i took everyone's advice and i was on my way to my friends shop to try and solve the lifter problem, and on the way over my car dies suddenly, very suddenly. It started to idle very very low and was un-responsive to me giving it gas, it back fired twice and died out. And now it won't even turn over, i get absolutely no Ignition, nothing. When i turn the key it acts like the battery isn't hooked up, my check engine light doesn't even come on like it used to, not even the beep sound when the key was in the on position, i tried replacing all the fuses and the one relay in the fuse box, nothing.
