Thanks guys, i do appreciate the help, allot. And yeah the last owner did kind've leave me with a mess. And yes jesse it's running with a carb, a Quadrajet something or another, I honestly thought this was the stock setup so that might be where half of the confusion is coming from. And DRIVEN i already picked up a new distributor and here's a link to it.
http://kmjent.com/cart/product.php?prod ... 406&page=2 <--new dist
And as for the computer system being in tact, not even close. I'm trying to eliminate what's left of the computer system for a few reasons, A. i Don't want any computer controlled systems on this engine, B. This system is so heavily damaged that there is no point in trying to save it.
As for the camshaft problem, I just want to fix the other problems first, then tackle that problem because it's a big one to handle.
The way i've got it planned out, when i go to replace the cam i'm going to be replacing the intake manifold and water pump at the same time, this will also eliminate any remaining computer components and hopefully make this engine run allot smoother. If i can work it out, i want to replace the heads at the same time i replace the rest of the valve train, because otherwise i'd just be going back and doing allot of the work all over again.
I've never built an engine like this before so i'm trying to plan out the best combination of parts for a good solid smooth running engine that's got some power to it.
I haven't got any work done in the last 2 days because it started raining :? but i should have some updates here soon.
