I pulled the trigger on them. Do you know anyone running them with a tall upper balljoint? I'm running one and some 2" lowering umi springs
im lowering my car with 2" umi lowering springs. These are direct screw in bump stop replacements for the lower control arms? All they do is just lessen the impact of the control arm correct? Does anyone do anything about bumpstops with the speedway tubular uppers?
I have the Tall ball joints. Wheel interference can be an issue with 17"X8" or smaller diameter 8" wheels. I run 16X8's but had to do some grinding on the ball joint plates for clearance.
The shock should top out before the upper arm hits the frame, so no upper arm bumpstop is needed... unless you are using off road shocks and are going for the rallycross look.
