79loserbluebu said:Did anyone have to remove the headers to install these? The LS1 headers are close but they seem about the same distance from the frame as traditional SBC headers
tavares86 said:When you install these, should you be putting the exact shims back in place?
Thanks. I'll be getting myself a set of these for sure.pontiacgp said:tavares86 said:When you install these, should you be putting the exact shims back in place?
yes...the tubulars fit the same as the OEM upper control arm
hy82e said:Bump, to hear from the guys with high daily driver mileage on the steel bushings. ALL bushings wear how many miles before you had to change them out.
