Square body crew
Clutch
5,188
10,913
Brick NJ
As for right now it seams to run perfect and it has oil pressure but the loud knocking/taping/banging? It's weird it's definitely coming from the right side but I have no idea what it is I'm wondering if something fell down the intake when it was sitting and got logged in the top of a piston?? Maybe something is broken in the valve train? Sounds louder then that though. I really don't know but if I can fix it I will
24,229
I've had that noise in my 63 394. Believe it or not, an Italian Tune Up fixed it. I've heard tell that a piece of carbon can sound like that. You have 2 options: run it and see if it goes away, or pull the head for inspection.
The Olds gods are steering you back to the 455.
  • Optimistic
8,835
7,801
Yeah, this blows. Pull the valve covers on it. I would pull apart the other 454, was the cam properly broke in on the other 454? Sucks to have to do this so many times. I am running a roller cam in my 403 stroker just for this reason. I have a stuck lifter in my Olds 350 I have to address as well before it goes in my 88 Cutlass.
Clutch
5,188
10,913
Brick NJ
That's this mornings plan but as the clock ticks money gets tighter and the parts to make the 455 work are already out of reach at the moment. Lost the buyer for the Grand Marquis.
  • Sad
Clutch
5,188
10,913
Brick NJ
That's the plan this morning first rip on the one in the truck and if it's a fail go to the other one. Yes it was broken in but Jay the mechanic 3 bays up said he had the same problem with his circle track race car and comp replaced his cam and lifters free. They told him that they had a quality control problem for a while and that's what the Machinist I have on speed dial now also said. The problem is I drove it for 2 weeks. How bad did the metal in the oil hurt the bearings? I'm standing in a field of unknown. Metaphorically speaking.
DRIVEN
8,098
14,618
*CENSORED*
I've run into the carbon nugget thing too. I did the water-down-the-carb-on-a-hot-engine to cure it. I really hope that's all it is.
19,996
nope
  • Sad
