Square body crew
Supercharged111
4,934
7,717
Colorado Springs, CO
Never say never. A 12V is tough to beat.
Especially in a square body. The Cummins didn't really have significant mechanical problems. Dmaxes split the occasional crank and are notorious for injector issues ($$$).
Clutch
5,189
10,913
Brick NJ
It's time to put the batteries back in this beast fill it with fuel and go do work! Looks like I'm going to have another weekend looking for those helicopters with all the running I need to do hopefully I end up with some updates to a few threads.
DRIVEN
8,075
14,536
*CENSORED*
Clutch
5,189
10,913
Brick NJ
So far nothing has gone to plan today! I swapped the batteries back out of the suburban and got the crew running. Then the suburban wouldn't start. So I decided to jump it off the crew I pull it forward and the left outside dual is flat and the inside is low. Fire up the compressor to fill the tire and it runs a few minutes then the crank case pressurized it blew out the dip stick and shot oil all over the cab. I managed to jump the suburban and move it anyway. Then I put what air did build into the tires. By that time it was snowing pretty good so I figured I would just put the plow on and scrap my original plan.
Once I did all that I was cold and hungry. Turkey sandwich time! Now I'm going to take the suburban out to the farm and swap the beat battery with the one from the blasting rig and get a portable compressor so I have air.
