Stalls when hitting gas
rubio9800
242
110
California
Hello everyone,
I need some guidance trying to figure this out. When hitting the gas from a complete stop the engine stalls/cuts out or it hesitates
to take off. Best way i can describe it, i’m not mechanic savvy, i know some basic stuff :)
This is my first project car
I’ve done the following trying to fix it:
-new spark plugs
-new wires
-new fuel filter
-new EGR valve
-new o2 sensor
-clean carburetor (did not take it out)
-new gas
-fuel system cleaner
Could it be IAC? Bar sensor? Fuel pump?
Carburetor needs adjusting? (idle sounds fine to me)
thank you everyone , i want to fully enjoy this ride :)
81Regal
1,558
485
83
Terril Iowa
Possibly the choke not working properly or vaccum leak, kind of hard to diagnose online. I doubt if its a sensor.
Does it run better with a hot or cold engine?
Supercharged111
4,942
7,740
Colorado Springs, CO
I'm confused, you mentioned O2 sensor, carb, and IAC in the same post. Do you have one of those late qjets that trims itself? If so, it sounds like an accelerator pump issue which is what MontesbyE was slowly getting at.
rubio9800
242
110
California
it’s an 81 265 engine , qjet that trims itself? sorry i don’t understand, i believe it’s a 4 barrel.
how difficult would be to replace accelerator pump?
rubio9800
242
110
California
i did not drive it cold , usually let the car run for 5-10 mins before driving .
it has an electric choke i know that, but i don’t know how to tell if it’s working correctly
there is power that is going to the choke thermostat , checked with a voltmeter
20,397
put a drop or 2 of oil around the alleterator pump shaft and let the oil drain down the accelerator shaft. Leave it for a minute and then start the engine to see if the problem diminishes. If it does then you need a new seal on the accelerator pump.
rubio9800
242
110
California
this is how i found the choke blade, cold engine.
is that partially open? should it be closed?
rubio9800
242
110
California
i need to find where it is and i will try that
