I greatly appreciate the offer. I do not have a splitter cable yet. I have used the software on my laptop to change my timing map. The Holley Sniper is not very friendly to a turbo blow through, but a Stelth is. I copied and pasted the better map and tweaked it from there. I plan on probably putting the car in storage till spring and working on the Nova this winter. So most likely I will not get back to the Monte till spring. What kind of Holley product are you using? I can not remember.Are you using a laptop or just the Holley display for tuning?
You can purchase a splitter for the CAN connector so that you can use both at the same time. I paid $50 for the splitter cable and it works fine. Much easier to use both the Holley 3.5" dash and laptop at the same time or decide which one to use without having to swap cables around. I'm mentioning this because if you head down the flex sensor path, then I believe you have to use a laptop for the programming and assigning the inputs - again, I believe.
I feel your pain being a heavy equipment mechanic. The one main reason I never wanted to get into that - winter.
Hold fast brother and speak up if you need something.
Jim
