Supercharged111
It has the big "W" shaped spring between the shoes. It wasn't fun to work on the first time but now I have the correct tool for it so hopefully next time will be better. I really prefer drum brakes on the rear so the answer is probably to just keep tightening them every 10k miles or so. I think part of the reason I burned through the last set of front pads so fast was that I was lazy about keeping the rears adjusted tight so the fronts were doing all the work. It may get a rear brake job this year. If not this one, then next for sure.
Yeah, I drove the truck around the block last night to see how they were aimed as I knew I'd be coming home from work in the dark tonight. The improvement is dramatic. I'm looking forward to having headlights tonight. Based on the ride home, I'll adjust them if needed but they looked good, right out of the box last night. I still prefer the smoked look but I don't think it is worth all the negative trade offs at this point. Thanks for the compliment. I've tried to keep it up. I haven't done as well as I should with the wax and it has taken it's toll on the hood and roof. Hopefully it will be parking in the garage at the new house before the end of the year.
I had all of these problems. I've had a few sets but the latest driver's side assembly I put on the truck after the wreck is the worst. The GM assemblies fit like a glove. Changing these is not that much fun. You have to remove the grill and the bumper cover. It's not that bad, but it's a bit of a pain if all you want to do is change a light bulb. Terrible design!
No, it came from the factory with a paper gasket. I've never seen the rubber gasket. I guess a reusable gasket wouldn't be a bad thing but I just got irritated that I couldn't get a paper gasket that day, upon request. In the end, I found the part number and the first place I had gone to earlier, NAPA, had it all along. Their database just didn't call for it. I still ended up paying $15 for a paper gasket. Ridiculous!
I'm not sure if the 9.5" diff came with drums or not in those trucks. It did in the GMT400 trucks and it's great because the brakes adjust themselves the way they're supposed to. Just another excuse to upgrade something else. I test drove a 2012ish Sierra Denali 1500 with the 6.2 and it had the 9.5" diff. NHT Max Trailering Package trucks got them too.
