Hey guys, back again for another update, so get comfy!
As most of you that are familiar with me and the 'Naut probably already know, when I get quiet here on the forum, it usually means I'm hard at work on something. Well, you'd be absolutely right, and lately has been no different. As it's name implies, progress on the Juggernaut never truly stops! So here goes...
To be honest, I was actually a little apprehensive about writing and posting this update.
Quite recently I read a thread on here where the conversation gravitated towards talking about lowered G's and big wheels. Both of which I have, the car is on air ride, and the wheels are 18"ers.
In that thread, I was somewhat surprised and taken aback when several members started slamming lowered G bodies and the big wheel look. I wasn't at all prepared for the negative comments on the subject!
It wasn't directed towards my car mind you, but it still surprised me nonetheless. The Juggernaut isn't among the lowest of the low, nor does it have the 24 and 26" wheel look of certain "other" G's out there, but it struck a nerve anyways for some reason. Hence my hesitation and apprehension on posting this particular update, since it has to do directly with lowered suspension...
But, at the end of the day, it's my car and its what I want, so the haters can just suck it up and deal with it. No ones forcing you to read this or like the direction I've taken with the car, so if anyone doesn't like it, there's the door; you're name's on the knob!
Lol
Anyways, here's what's been happening in the "toybox" as of late.
While I've previously touched on and had the AccuAir air management system for a couple of years now, the system hasn't been fully installed and functioning up to this point. There's been several factors for this, primarily because considerable fabrication had to take place and be completed in the trunk and on the rear suspension to get to the point where I could start finalizing the air management and functionality end of things.
After the successful completion of the grilles and headlight bezels, I dove right into working towards rectifying that.
All the air lines under the car are stainless steel hardlines front to back with the exception of the front where there are short sections of high pressure flexible braided stainless hoses that attach directly to the front shockwaves for some forgiveness in movement. All this was completed some time ago, but where the current problem lay was where the hardlines needed to connect to the bulkhead connectors that come through the trunk floor.
The hardlines were purposely cut and left long while the body was still off the frame last. With the body back on, I now knew where the lines needed to be trimmed to, but there was a lack of room to spin the tube cutters to actually accomplish the task.
I overcame this hurdle by swapping my sharp stainless cutting wheel from my regular sized cutters over to a cheap "mini" cutter. It still took a bit of effort, but it was just the ticket. Once the lines were trimmed to the proper length, I was able to slide on the tube nuts and sleeves, and make the necessary 37 degree flares on the ends of the tubes.
With the final work completed on the pneumatic side of things, I needed to get onto the electrical. While not difficult, the wiring needed to be just as carefully thought out and planned as the rest of the car. After some careful thinking and experimenting with different options, I decided to mount the compressor relay (which is central and primary for pretty much everything) to the back of my custom built rear firewall. Here's the schematic of what needed to happen:
I traced out the mounting flange of the relay onto some 1/8" flat plate and cut it out. I then drilled and tapped the holes to accept the stainless button head fasteners I'm using throughout the car. With this done, I plug welded the plate about 2" above the trunk floor to the backside of the firewall. It needed to be welded as any fasteners I used would show directly on the frontside of the firewall, unacceptable!
2" above the trunk floor was chosen to keep the relay hidden behind the tank and compressors, yet keep the wiring fairly close to the trunk floor. (Sorry, no pics!)
With the relay mounted to the new plate, laying out of the wiring could begin. A 7/8" hole and a grommet were drilled and installed far under the package tray through the passenger's side upper inner wheelhouse flange for the 4 gauge power wire and 70 amp fuse to run through to the trunk mounted battery.
Another 7/8" hole was drilled in the trunk floor and grommet installed directly under the air tank for the ride height sensor wires to pass through to the underside of the car. With this done, all the wires were sleeved with some bulk "split braided sleeving" from a local electronics supply store, and terminal ends were crimped and soldered on.
The spilt braided sleeving:
With this completed, the tank and compressors were reinstalled, and the wiring was plugged into the ECM. The power and ground wires from the compressors were connected to the relay, and the pneumatic lines were reconnected again as well. The Optima battery was dropped back into its mount in the spare tire well, and a temporary ground was run to the body.
Here's the install with everything connected. (Note, the trunk floor still isn't painted or finished, there's more work to be done there before I can get to that point. This exercise is just to get the air hooked up and working on its own).
Hopefully you'll note the absence of much visible wiring at the compressors, that's kind've been my signature trademark for many years. It's pretty tough to make wiring look good and/or clean, so I try to hide it altogether whenever possible.
With the wiring and pneumatics all connected, it was time for the moment of truth! I plugged in the controller, connected the main power cable and switched 12 volt wire and presto! Running compressors!
I nervously watched and monitored the compressors, and as intended, they cut out automatically once they hit pressure (determined by an in-tank pressure sensor).
Time to start playing...
I should mention here, that this is just the initial test run of the equipment; just to make sure that the wiring, ECM, and pneumatics all function as they're intended. My particular AccuAir air management system incorporates what AccuAir calls "E Level". This means the system uses ride height sensors (basically fancy potentiometers) mounted at each corner that read ride height and relay the info back to the ECM for adjustments to the ride height (within a 1/16 of an inch at each corner!) These sensors and their related components are still to be installed.
This means, as you add fuel, luggage, cargo, or your "hefty" friend into the car, the ECM will automatically compensate for it, and re-level the car. AccuAir calls this a "semi-real time" application. Adjustments to ride height to level are only automatically made after 45 seconds, so that it doesn't happen while driving which could lead to unexpected and dangerous changes to handling characteristics.
Anyways, I rarely take videos of stuff, but I figured if there was ever a time to do it, it was now! Unfortunately for me however, the site here won't let me upload the vid, it's too big apparently.
I'm not about to go through the rigmarole of signing up with YouTube and jumping through their hoops just to post a short crude video of me playing around with the air, so you're all going to have to make due with some pics I guess. Sorry guys.
Anyways, here they are. First time the car has EVER been up and supported on its own accord!
It's a shame that I can't upload the video, I even tried taking a super short one about 8 seconds long, but the site always says the files are too big. There's nothing quite like seeing it do it's thing in person!
In case the pics don't quite convey it, the car sits VERY low for a G body when aired down completely. For comparison, the famed Ford GT40 from the sixties got its name from its 40" roof height. The roof height of The Juggernaut is between 50 and 51" (difficult to tell due to the roof curvature) when aired out!
It's not "laying frame" or rocker panel like the trucks do, but that's plenty low for a G body and pretty respectable I'd say.
Overall, there's about 5" of travel at the rear, and 6" at the front. More than enough to make a dramatic statement and altitude/attitude change!
Anyways, that's about it for now. Once the novelty of being able to play around with the compressors and ride height wears off a bit, I'll put the car up on stands and remove the wheels to begin the ride height sensor installation.
That'll be a whole 'nother update all on its own.
Thanks for checking in on the progress as usual everyone!
D.
P.S. - I have a couple more pics, some with a tape measure for reference and idea of heights that I didn't post here. Let me know if you guys want to see those, or of any different angles etc. I'd be happy to accommodate if there's interest.
