BUILD THREAD “The Juggernaut”
Rktpwrd
Builder of Cool Shjt
4,177
23,956
Calgary, Alberta, Canada
Why don't they mix? I have 2" drop spindles with my all iron big block with no issues....
It's dependent on your wheel and tire size and particular headers you're using.
In my case the drivers side header is the lowest point on the car, and was the first to come into contact with the road. Every car and combination is slightly different so you may be one of the lucky ones with no issues.
liquidh8
That was my case also, along with some bump steer issues, I had stock springs at first, then moog. Everyone's mileage may vary.
O. D. Showtime
3,008
3,539
Regina Sask. Canada
Haven't checked in for a while Donovan...love the headlight mod, very cool looking.... car's progressing nicely! You do some very fine work!
Rktpwrd
4,177
23,956
Thank you Kevin!
I'm glad you like it, I'm very happy with the way it turned out as well. Once I get the grilles and headlight bezels refinished, I'll post some pics of the front end all together so everyone can see the finished product.
It's good to see you back on here. Hopefully you're out of the woods with your health scare and are feeling better!
Rktpwrd
4,177
23,956
Well, it happened a couple of days later than I had originally planned, but baby's got a couple of new coats on her just in time for winter!
I don't know if it comes across in the pictures, but it looks amazing in person! I'm going to leave the spray on guidecoat off this time around. It looks so much cleaner this way...
I'll just use the dry guidecoat when it comes time to block it out next time instead.
Tomorrow I'll unmask it and install the header panel and post more pics of it then when it's all together and looking more like a car!
:banana:
cblazer1500
47
Altoona, PA.
I'll be calling on your expertise in the next few weeks on your engine/exhaust set up... Got me a 455 coming soon which I'm totally stoked for..... Great work as always!
Rktpwrd
4,177
23,956
Call away sir!
I'll be happy to help in any way I can. The 455 is a great engine, especially if you like the feeling of big torque off the line. They need some attention in a few key areas of you plan on improving the power and performance levels in them, but they're well worth it IMO.
Congrats on picking one up, looking forward to seeing it and your plans for it!
cblazer1500
47
Altoona, PA.
It has the edelbrock heads and all the machine work done including balancing the rotating assembly. Speed pro 40 over pistons. Basically it's a fresh motor build. I'll be putting in roller cam, lifters and rockers.... Questions I have are what mechanical fuel pumps will fit using those heads and what length push rods to use.
Rktpwrd
4,177
23,956
I'll respond to you in PM shortly...
Rktpwrd
4,177
23,956
Well guys, here we go.
Here's the culmination of all my hard work and effort lately. It's finally all fit and bolted back together, and in one colour, even if it is only primer for now.
The header panel and headlight mod is now officially done. The grilles and headlight bezels are all that's left, then it's on to the filler panel and finishing up the front bumper before getting back onto the hood.
:banana:
As promised, some pics of the finished product (minus the headlight bezels):
So what's everybody think???
o_O
