Hey guys whats up? I'm about ready to drop in my 5.3 into my Bu and converter is really the only thing holding me up. Il try to make a long story short but Ive called around a few local shops, TCI, and B&M about recommending a few converters for my setup. The main things they wanted to know was compression ratio, cam duration, so on and so forth. My cam card said 300 advertised duration so i told them that and about 9.5 compression ratio give or take a few points and my trans th350 etc. Basically the answer i got was anywhere from 2700- 3100 flash stall speed so i know what to get. My problem is they really stressed to me for it to be a proper setup was to run a 3.55 to 4.10 rear gear which i don't have im still doomed to the stock 2.28 which i didn't really think about until one of them brought it up. And im no trans expert but if im pulling 1900 rpm at 60 on the highway in a non lock up trans with a 3000 converter wouldn't that generate a ton of heat and burn up my trans?? Im gonna change the rear gear when i can but is it safe to drive until then cuz i really don't know when i can change the gears. Should i run some big A** cooler??
Also this is the first time ive ever used anything but a stock converter so if there is anything i need to know any help is appreciated
