Transmission Recommendation?
JoeF419
13
6
33
How will the car be driven? Around town? Highway? Combination of the two?
If you're leaning more on the "cheap side", then maybe a TH350 would be your choice.
An overdrive trans will run you considerably more.
Stick or auto?
It will be my personal car to take me everywhere, so highway and town
200-4r or 700r4(4l60) would work also
joe
200-4R. If I had it to do over, I would have built a 200-4R instead of the TH350 I built. They're geared very similar to a TH350 with the addition of overdrive and with some tricks and tweaks they can be made to handle plenty of power. Do a little research if you decide to go with a 200-4R. There are different "versions". Different codes on a little metal plaque towards the rear of the unit identify which vehicle it came from. Different cars got different valve bodies. Some were more performance oriented than others. I think the governor may have been different too. In addition to this there are 3 different bellhousing patterns as well. Chevy only, BOP only and a dual pattern that will fit either. The dual pattern seems to be the most common.
Check out V8 Rumble's transmission build thread.
My 86 SS came with a dual pattern 200-4R case. Like Opie Knievel said, starting with the correct version will save some coin. The governor on the turbo Buicks allow the highest full throttle shifts. A little grinding to lighten the gov on my Monte allowed for a 5600 full throttle shift point which is probably why the 305 puked it's guts. A simple vacuum switch adapts converter lockup and a wire to the brake switch unlocks it.
