I have an 81' El Camino, pretty much stock. I recently changed the front and rear springs, front upper and lower control arm bushings and ball joints. Since I did this work the car leans noticably to the right, mostly the front. When I measure the height it is about 3/4 to 1'' difference. You can see the rear is also uneven. Before I did any work I noticed the same problem but thought it was due to the fact that the front springs were both broken when I took them out. The car has never been in a serious accident. I cut the front springs to give me the height I wanted. I have tried everything and can not get it right!!!
THIS IS WHAT I HAVE TRIED....
-Swapping both front and rear springs to opposite side
-Replaced rubber pads for front springs
-Removing sway bar
-Removed brand new shocks
-Removed springs and made sure they were both same height
-Loosened all bushings front and rear, bounced, then tightened
When I loosened all the bushings I thought I had it fixed, while they were all loose it was sitting even. I drove it onto stands and jacked up the rear so I could torque them with it at ride height. After I torqued them it looked good, I drove it down the alley so it would bounce a little, parked it in the garage and now it looks the same again! I swapped the front springs to see if it switched tot he other side but it didnt so I know it is not the springs. I have also made sure they are in their pocket and seated correctly. I dont know what to do!?!?
-Removing sway bar
