You can. To explain the difference between an anti-roll bar and sway bar (in case you didn't know), the anti-roll bar does not bend/flex like a sway bar does. And it is attached to the frame or body at point that doesn't move separately from the body or frame, unlike a sway bar that is attached a suspension component.So if I put a anti roll bar in the rear do I take the front sway bar off?
I dont know much about anti roll bars, could you explain how they are dangerous on the street just to clarify in my mindYou can. To explain the difference between an anti-roll bar and sway bar (in case you didn't know), the anti-roll bar does not bend/flex like a sway bar does. And it is attached to the frame or body at point that doesn't move separately from the body or frame, unlike a sway bar that is attached a suspension component.
You shouldn't notice a difference if the front sway bar is hooked up or not. So that means it can be removed. Lastly, don't drive the car on the street at highway speeds with the ant-roll bar hooked up - it's somewhat dangerous.
