I'd rather drive it than swap engines.Found a spare $500 gen 3.5 6.0 LQ4 Complete with harness, ecu, ac, and a nice PS pump.
LS Swaps are expensive?
Who said it's for the regal?I'd rather drive it than swap engines.
Nice! I just saw they recently released a new Drag Radial. I might give it a shot.Nitto tires came today
They were delivered by my new best friend View attachment 141643 View attachment 141644
Not me. Got a guilty conscience?Who said it's for the regal?
Maybe, and maybe I like building motors more than body work. Need an isolation distraction.Not me. Got a guilty conscience?
Not reallyFound a spare $500 gen 3.5 6.0 LQ4 Complete with harness, ecu, ac, and a nice PS pump.
It's like having kids, second and third are cheaper.Not really
Just light another 2-3k on fire now.
I probably mislabeled the part. Its the rear seat crossmember that holds up the backseat and makes up the #5 body mounts. I replaced it because the original looked like this and the ends were deteriorated.RabbitHoleSS, Would you mind taking some pics, posting installation of your brace, if you can tell any difference and if the brace was worth the time and money.
I probably mislabeled the part. Its the rear seat crossmember that holds up the backseat and makes up the #5 body mounts. I replaced it because the original looked like this and the ends were deteriorated. View attachment 141711
Now ill day the goodmark repop wasnt bent as tight but it fit good. Just had to clamp and hammer the spot weld holes flat.The only spots that were an issue was the hump. View attachment 141713
The top where all the spot welds are. View attachment 141714
The sides where it mounts to the inner rocker. Again there was a 1/8th inch gap on each side. I spot welded it first. Then used a hammer to "stretch" it out.
I cant complain it fit as good or better then I expected. If your car has a rotten. Rear seat crossmember its "worth it". I wouldnt really know because my car looks like this
And the driver front seat brace looks pretty much identical to original. Now if you were talking about the braces that come in between the trunk and back seat. I think ill make my own if I even put any on it. Hope this helped clear things up.
I'm glad that it worked out for you. This is is the brace I thought you were talking about and what I have been looking at for my MCSS.I probably mislabeled the part. Its the rear seat crossmember that holds up the backseat and makes up the #5 body mounts. I replaced it because the original looked like this and the ends were deteriorated. View attachment 141711
