after
Replaced the intake gasket, as I had an annoying oil leak.
parked it in the back yard for a undetermened time . need to save some cash to get it all fixed up for the road again .
Is a build starting up?
Went to the junk yard and found a complete wide belt set up for the alt. and water pump. Still has the Vbelt for the power steering so its a nice set up for the high RPM of the 377 stroker motor.
Spliced the underhood light wire where it comes out of the firewall and ran some wire next to the hood latch and installed a switch.
For working under the hood for extended periods of time so you won't drain the battery.
Dreaming about it.
Changed out the shifter to a B/M Stargate from the shifter the guy tried to put in before. Works great and now it shifts through all the gears. Also added 3qts of trans fluid, not sure if the guy before had a clue what to do when it didn't move forward. Tonight if I have time to change out the rear break shoes and get those corrected .
