MrSony, you need to chalk the tires and make a test run. I agree that they appear to be overinflated, the rating on the sidewall is a max pressure, not what the target is. Variables like load, wheel rim width, desired ride quality all affect the correct inflation PSI
Should have pressure at 32PSI
Based on what? OE tire/wheel assembly?
I think he's got 235/60s on it. 7 or 8 inch wheel will require different pressures to maximize tire contact patch and treadlife.
There is no blanket answer for tire inflation...even the OE spec is a compromise based on treadwear, noise, ride quality, fuel economy/rolling resistance, and load capacity.
There is no blanket answer for tire inflation...even the OE spec is a compromise based on treadwear, noise, ride quality.
Been running them at 35psi. 30 psi and they would seem to squat, if that's the word for it. 235/60s on 15x7.
Almost guarantee you that's too much for a 235 on a 7 inch wheel. Usually works OK on an 8 inch wheel
Best way is to chalk them and adjust accordingly
Thermostat is f*cking leaking again. I'm about to dump this thing off a cliff. I'm going to replace the gasket AGAIN. And try my steel thermostat housing, as opposed to the cast aluminum one. What I don't understand is it was FINE the WHOLE day yesterday. Drove about 70 miles. Beat on it a little bit. Was fine last night as I was doing stuff. Come out this morning, it's got a puddle on the intake. Mother******.
Recommended pressure for any given tire is molded into the sidewall.
If you have time, let the RTV cure for a day before you put coolant in. I think I drilled and tapped my Olds for bigger bolts. Because, you know, bigger is always better!
Looked at them , as they sleep for the winter......and dreamed about installing the current parts on the shelve.
wait football is on ...got to go
No, max inflation pressure is molded into the tire, recommended pressure (for the specified tire size) is placarded on the vehicle (commonly in the door jamb label since the late 70s, glovebox for Chevs of the 60s)
Agreed, RTV needs to cure before being placed in service
Did the manifold get checked for clean, unpitted, flat mating surface for the tstat housing?
Reactions: Wraith
are you sure it's the thermostat housing gasket that is leaking?
Reactions: TURNA
