Pulled the intake to rerun the Holley harness. When I first put the Holley in it I ran the harness through the factory hole, out of ease and necessity. Always hated it. Decided change that today.
Fuel system planning, ugh. Only another couple hundred of $ in fittings to buy. Went with PTFE lines hence the giant sizing and hopefully no obsolescence with future power gains. All Fragola line, Fragola fittings, Motion on flex fuel sensor mount, and Aeromotive on filter and regulator.
I've used Summit fittings with a Fragola PTFE hose when I made my pump to carb line.
Put one of them away for the winter, and cleaned up The Skunkworks. Cruising season is done for the year with snow forecast for the next week, but build season is just ramping up!
Olds Cool got the tank topped off, fuel stabilizer put in, the battery tender put on, then wrapped up and tucked away.
The Rktpwrd shed got stuffed to the rafters with a bunch of miscellaneous parts, two dashboards, and the last of the yard stuff, then I gave The Skunkworks a decent cleaning so I’m officially ready to rock on The Juggernaut this winter!
This is probably the cleanest the shop has been in over a year!
I’ll have to give them a look. Cart at almost $1k to finish system but that includes 20’ of hose too
I used summit braided stainless PTFE hose in a few spots, and would use Fragola if I did it over. Much easier to cut and put ends on it cleanly.
What regulator are you going with?
Reactions: Wraith
