Finally got an around to putting the fuel tank in. It was a little tight with the stock straps and the filler neck was a little high up. Both of which I expected. For the neck I stuck a long pry bar in the filler neck and gently pulled down on it.
While I used new straps with my tank swap, I too had to pry my filler tube down a bit also.Finally got an around to putting the fuel tank in. It was a little tight with the stock straps and the filler neck was a little high up. Both of which I expected. For the neck I stuck a long pry bar in the filler neck and gently pulled down on it. View attachment 231084View attachment 231085
Better then than in a parking lot somewhere!Put on the Bilstein AK shocks on the rear. What a difference over the KYB Gas-A-Just shocks that were on it. Nice and solid and no more metal on metal.
Also took care of the leaky thermostat.
When I got to my friend’s house to do the work, I went to start the car to pull it into his shop only to find out the starter took a crap. So, also did the starter too.
...in the middle of winter....that hasn't been plowed....and is covered with frozen slush 🤬Better then than in a parking lot somewhere!
Sorry for the late reply on this! I have to call and ask exactly what he did, but basically he built it to handle around 600hp. I'm shooting for high 400s to the crank, so I have plenty of wiggle room there! Based on the cam specs/gear/tire/etc. I had him do a 3000ish converter in it as well.Very nice what upgrades did the shop do for your 200r4? And how much hp is it handling
If we have frozen slushy parking lots here in Phoenix then there's a more serious problem....in the middle of winter....that hasn't been plowed....and is covered with frozen slush 🤬
