The plan was to roll the '68 Firebird project out for the roll bar fitment. The battery was so dead it would not even grunt. On goes the charger but what to do instead? The Bonnewagon has been running a little rough so how about a tune up? I pull the spark plugs [not bad], clean the plug wires, yank the cap and rotor [Yikes, has it been THAT long?!?] Good thing I have a new Blue Streak set stashed away. Drain the oil, remove filter. Know what? Let's spray the whole mess down with Purple Power and do it right. I cover the distributor and carb with plastic bags and blast away. Then I install new plugs [.060" gap], new cap and rotor, clean plug wires, new air, fuel, and oil filters. I am trying the Mobil 1 full synthetic 0W-40 European blend in the 301. I have been using it in my Jeeps and I like the wide temperature range. While under there greasing the steering stuff, I smell gas. Oh crap- the fuel line is leaking at the pump. I try to tighten it, and realize the whole pump is loose. Damn, a bolt is stripped. I already replaced the other one with the next oversize which for 5/16" is 8mm. Luckily I save metric stuff and I found another 8mm bolt and after that the pump is on solidly. Removing the hard gas line and re-tightening it must have re-seated it because the leak is gone. I replaced the 3/8" rubber frame to pump line too as it looked dodgy. Once it was all back together I fired it up. NICE!! No need to touch the carb as now it idles as smooth as it used to. And everything is CLEAN! I finished this yesterday and good thing too as someone turned the furnace on again today.
