What did you do to your non-G body project today? [2018]
New skin on the bike
In the ongoing Fjord saga today I am taking the trans pan off for the 4th time in 3 days because it will not seal up. The only comfort is that unlike GM they had the sense to put a drain plug in it from factory
Reactions: pontiacgp
Replaced the sparkplugs and boots in my CVPI. Changing plugs on a Ford 4.6 is not easy, the holes the spark plugs go in are really deep. Had to use a hemostat to pull the old plugs out once unscrewed.
Had some unexpected time off from work. Took advantage and gave the daily driver some badly needed attention. Oil change, tire rotation, adjusted the rear brakes (the self-adjusters just don't keep the shoes adjusted tight enough for me), oiled the door hinges (I like to use an old school oil can and flood them with motor oil and then wipe up the mess), and cleaned it up inside and out. I've had little time to spend on it so it was nice to give it some TLC.
Finishing up one of several random projects today, speaker stands for some custom built speakers that I don't use since the niece invaded my stereo space. Built with Home Depot sourced oak/PVC cut in the garage, routered/stained at the neighbors house, and finished up in my garage with sand. I did use 3m Strip-Calk to seal the PVC to the bases.
Next up, eventually is a sand box for my turntable. Maybe. Eventually.
