What did you do to your non-G body project today? [2018]
10,575
14,318
Wraith- NICE HOG! Ape hangers and all!
10,575
14,318
Today I broke down the 235-75-15 Wrangler tires that were on the Jeep's alloy rims. 2 good- 2 shot. Then I installed some new Sears Guardsman 225-75-15 LT tires I scored the other day. They were a closeout and I had to drive the Bonnewagon deep into Brooklyn to the Bedford Ave Sears Auto center to get them. $40 each out the door. Those went on the alloy rims for summertime. The Wranglers I put on the factory steel rims for winter duty. I did all this with my $34 Harbor Freight tire changer tool. It works pretty good after I bolt it down to the cement patio. One tire was impossible to seal the bead so I resorted to the shade tree brake cleaner explosion method. BOOOOOM!
Wraith
1,602
4,764
DFW, TX
So an easy exhaust sway turns into a fiasco after I find the exhaust mount bracket broke in two. To remove it you need to remove the clutch cover and then the oil filler neck, both cover one bolt that can't be removed without them in the way. Great. Bracket off, welded, and painted for install tomorrow. Then I can get back to the original project.
10,575
14,318
Balanced the steel Jeep wheels this morning at a friend's shop. Then I dove into the rear brakes/combination valve ordeal. When I re-assembled the shoes I purposely left out the self-adjusters which never work right anyway. Without them I watch the hand brake and when the travel gets too much I know it's time to manually adjust the brakes. The combination valve went well. Flare nut wrenches a must. After bleeding the whole system I went for a test drive and there is no more locking up of the rear brakes. In fact my daughter says the brakes haven't felt that good in years. Rain tomorrow so I'll balance the new tires and if it lets up enough I'll put them on. While under there I noticed the transmission cooler line is leaking. Endless work!!!
Emmanuel cuellar
732
253
big block ford 390 6.4 a buddy of mines gave me he said he not into fords just like me we GM guys but if any ones intrested im in houston tx
wonderboy24
1,322
1,300
Davenport, Iowa
i have been doing rust repair on my daily driver 97 Ford F250. i have been looking for a good bed for awhile. they are hard to come by here. i found a guy that has one 2 hours from me i called him and he told me he had one for 400.00 with some damage but he would give me the repair part off another bed.i said that works i asked him to send pictures of the bed he told me i dont do that trust me this one is rust free.i told him your 2 hours from me i dont want to waste my time. needles to say i didnt buy it. but yesterday i seen one on Craigslist
its and hour and a half from me the guy is asking 600.00 for it its even the right color. told him i need to find out how to haul it. He told me throw him an extra 50.00 and he will deliver it.i told him when he is heading this way i will send him 100.00 via paypal as a purchase so if he dont come through i wont be out the 100.00. he is supposed to be removing the bed tomorrow and bring it down Thursday or Friday this coming week.
Streetbu
Know it all, that doesn't
3,746
11,644
Central NY
Had a severe oil leak from the Briggs & Stratton v twin on our riding mower. Found out it was the base gasket. Pulled the enfine, flipped it upside down, yanked the base off. Yep, blown out by the starter. Common problem when they get some hours on them. Six hours start to finish and then mowed the lawn. Also found the drain valve was loose and leaking too. Also had a huge mouse nest in it from the winter.
