Luckily I put off being lazy to the last minute and got the front tires replaced before the first big snow yesterday
Haha, nothing on your level. Was actually more of a smart *ss remark since this is the first of the white stuff we got for the year that stuck. Everyone around here loses their mind like they have never seen it come down.![]()
"Big snow".
Exactly, rears were still good. This is the second pair of fronts I have had to put on in a year, first ones they warrantied out and thought it was a fluke run of bad ones from Cooper since the guy picking them up said he actually had picked up a quite a few recently for warranty. Now I am not so sure about that, but will have to stop being lazy and see what all is going on with the front suspension to see if there is anything causing it. I would understand if it was balding one spot on the tire, but pretty much the whole tire was going bare.
My progress follow-up on my OBS truck.....I finished up the brake rebuild on my '99 OBS truck....
*Rotors
*Calipers
*Pads
*Wheel bearings/seals
*Hoses
*Master Cylinder
*Rear wheel cylinders
*Rear shoes
*Drums
Well there still seems to be some post work diag effort needed. Bled all 4 corners per usual. Did 3-rounds after purging all air from the lines first. Sprayed everything down w/some brake clean so I would have dry surfaces when leak checking. Took a couple laps around the neighborhood. Stopped as expected. Re-checked for leaks & found 1 area where there was moisture (front driver hard-line to hose connection). I re-cleaned that spot because i couldn't tell if it was some remaining fluid or an actual leak. Master cylinder volume looked good.
Did a couple more laps w/o issue. No visible leaks/moisture from seeping brake fluid upon re-inspection. I stopped & had some dinner @ my local pub. Was driving over to my GF's house & when I slowed to turn onto her street the truck shuddered. That's definitely new. My mind immediately went to 'ABS' shudder as the default issue. I parked @ her house, grabbed a flashlight & inspected all line connections & bleeders. Everything was still dry/clean. The fluid is still full (same level).
I guess tomorrow @ lunch I'll pull the wheels off & check braking surfaces for moisture or fluid. No dash board MyABS warning either for what that's worth.
Or, you could just go back to the original plan and throw a plow on the TBSS until Natasha consents to a utility tractor or bobcat.... much less work.More work on the snowblower. FML.
Go to take rip with the ol' General and she's kicking the auger belt off like a mule and had no forward motion. Whhhhhhhyyyyyyy?! After hours of struggling and fiddle f*cking around with things I realized that:
a) it is kicking the auger belt off because I tightened up the chain, thus loosening up the belt, and any misalignment was now enough stacked tolerances to create the nonsense;
b) the lack of drive motion was due to a lack of belt wrap around the input pulley at the transmission.
So what do? Take the ideas from the back of the mental filing cabinet and get to modifying things.
First order of business was to make a pair of roller followers to help maintain belt tracking when the tensioners are idle, with the one at the rear going to the drive input to serve as a means to achieving more belt wrap (supercharger logic). The factory guide pins/fingers were never meant to ride on the belt. Second was realigning the tensioners. Last up was to make a non-abrasive guide for the back of the auger belt... this had been exposed threads chewing the back of the belt since new. Those threads were also very short and the auger belt would slip to the wrong side with stretch and wear.
While I was doing this, I am happy to report that Natasha was successful in finding me a handful of new belts. I am also happy to report that it kept the belts on. Yippie! But, of course there is always something else.
View attachment 189937View attachment 189938
It kept getting stuck in all of the deep loose/powder due to a complete lack of traction. Frustrating to say the least. This is a direct result of the fact there is no traffic going back the shop... so nothing is getting compacted. So I spent a couple of hours hand-bombing more snow to clean it all up.
Time for some help.
