What did you do to your non-G body project today? [2022]
... not where I thought that was going. Couldn't figure out the 36" pool vs a 40 gallon drum but each to their own... and the lack of yeast.... then the lightbulb turned on and we were talking about different things. 🙂
Have you perhaps considered 12v electrolysis to remove the rust? Baking Soda a battery and a 12v charger ?
Not sure where the 45 gallon drum notion came from. All that is going on here is the creation of a soaking tub for rust removal. The choice of feed grade molasses is to avoid the whole yeast and mold/penicillin business. Feed grade m-ss is bio-degradable so disposal is tipping over the wading pool once done and letting the lawn get some nourishment out of the deal. One suggestion is to just dig a hole and dump it that way but the water table here is so high that just lifting the sod gets you back flow. I do have a resource for determining the ratio/proportion of m-ss to water. The only thing holding me back was the need for a bit of work that had to happen to my Wheee-ler to make it easier to attach cargo and ratchet straps without having them droop and fall off during the process. Got that done this afternoon; nope, no pictures, not yet at least.
I have a really good spiced rum recipe if you change your mind and take Axisg's advice.
  • Love
Reactions: axisg
So what goodies will that buy the monte? That's the real question
Probably an oil change haha that car is pretty damn fun to drive as it is.
I do have some rear body bushings that are wore out, I'll have to look into that.
Well, she is about 40 years old. By that age most ladies have some sagging in their rear body, unfortunately.
Reactions: mclellan83
Yup. My woman doesn't so I'll take the one that I can fix up. 🙂
Bought this last fall, with plans to fix it and flip it. All torn apart, engine didn't run. Swapped the old school points for a new style magneto, rebuilt the carb, serviced it. Starts and runs on the first pull now. Been tripping over it in the garage, decided it was just time for it to go. Guy drove from 3 hours away to buy it. I profited $200, only had about 2 hours into it.
Then found this and promptly bought it. 🤣
10kw propane home generator. Has 99 hours on it, wouldn't crank, guy was told it needed a starter and battery. Both are fine, it's missing the cap and fuse for the starter system 🤣 Oh and did I mention I snagged it for $550 which also includes the automatic transfer switch? Score!
I hosed the pollen off the F150 and Fluid Filmed a lot of the frame. It's a 2015 with just under 80k miles on it. The body is still spotless but the frame is starting to show some surface rust on the welds and the more exposed areas. I didn't do use the cavity wands or pull the wheels off, I just hit where I could reach. I'll go back and recoat it and spray inside all the holes before next winter.
That is a damn good score. I got this one from a guy local for $250. Generac 5550W with 8550W Surge Protection. Ran on first pull, just needed a little bit of cleaning so I went through it all and cleaned everything up. Built a cord so I can use it to power my house by back feeding through the Dryer Connection.
