What did you do to your non-G body project today? [2022]
CopperNick
3,367
3,027
Canada
Phoned the order desk over at the Napa store and ordered a whole mess of Metri-pak connectors for my S-10 power window project. They may arrive later this week; or not????
Supercharged111
4,936
7,721
Colorado Springs, CO
Didn't do squat, but got parts today from Built6spdMCSS for my broken 1 year only M29 T56.
Been sitting on it since 2018 when I wasted 3rd. Never tore it down to see how bad it was, but now I know no matter what damage I did it can be put back into slam bang shifting status. Inside is 1st, 2nd, 3rd, input shaft, counter shaft, and a couple of release bearings that are about unobtanium outside of a clutch kit. Great for a guy who likes to piece together cheap extra stuff for when crap blows up at the track.
Built6spdMCSS
5,826
9,747
Florida Beach
No problem, extra stuff that I have no use for so I get it to those who can use it. I keep a couple parts around that are like that for the stuff I run.
I mess with the LS Fbody T56 stuff because parts are all over for them.
I play with trannies for my hobbies, my weekends get a little exciting..😃
Supercharged111
4,936
7,721
Spent way too much time trying to replace a zerk and grease 4 little fittings on the Envoy. The zero itself was broke off inside a 90 degree adapter. I just drilled until a bunch of chunks came out so I could run a tap down the hole, somehow I managed to have a 1/4-28 on hand. Now for the fun part: getting grease into it. What a stubborn b!t©h! First problem was I couldn't get any as$ on the gun without the coupler blowing it around the fitting. It's my new Lincoln gun. The gun itself seems solid, but the coupler was a POS. At first I tried to tighten it a few times, but that did absolutely nothing. So I stole the fitting off of my old gun I should have thrown away and all of a sudden I could put some effort in. Still no go. At this point I'd had the fitting back out 3 times to verify it flowed and to see if even 1 drop of fresh red grease was in there. There wasn't, but I'd already scooped multiple gobs of it out from around the fitting itself. I was pretty fed up, but not ready to call it as the ball joint is pretty fresh and I want to keep it that way. So I decided to hit the joint with a propane torch and while I was letting the heat spread jumped on the Google machine. One of the suggestions was to turn the wheel full crank. I tried that and grease began to flow slowly, then normally. Thank God. I decided to send 30 pumps through that m'fer in case it decides it's gonna pull this crap again. Get it as squeaky clean as possible. I don't recall how much grease I was able to get in there when I initially did the things before their less than 2 year old boots were already torn, but since they were I went ahead and used it as a drain for the old stuff.
Wraith
1,602
4,764
DFW, TX
Too cold to open the door or go outside so let's try out the mock-up wheel on the Camaro
We had originally thought a TorqThrust style but these work too.
Reactions: 7 users
6,832
6,741
trans am style dope
6,832
6,741
fixed my floor for a cool $20
