Got rid of the 40+ year old pushmatic service panel for something newer. I'm sure there's aspect that aren't to current 2024 code, but it's substantially better than previous Setup.
Split few circuits that were combined as well, mainly perimeter outlets.had some 12-18 outlets on a single 20A breaker🤦🏻‍♂️ at least they ran 12/2 stuff which predates colored sheathing.
Not adding any more electrical load than already was there previously but man that old box was tight
Split few circuits that were combined as well, mainly perimeter outlets.had some 12-18 outlets on a single 20A breaker🤦🏻‍♂️ at least that ran 12/2 stuff which predates colored sheathing.
Can do 13 outlets per the 1.5A rule on a 20A breaker unless I'm missing something? So not too crazy ridiculous.
I'm not up to speed that much on limits. It's probably fine, but I didn't like it much. Also that pushmatic had 12 spots so they probably combined circuits for that reason mainly, new box has 20 spaces and light circuits I can run 2 circuit per space..
my shop is 60*80 pole barn that was built late 70s early 80s. My gues they used it for block heaters on tractors in the winter (Ohio).
It's a North/South facing building, with door on the south side, so I split it in to east/west circuits, did same thing to the lights, even though everything has been swapped LED. i could technically put ever light circuit on 1-15A breaker. Being surrounded by fields mice/squirrels can be an issue and I'd rather loose one string vs everything
I'm putting together a bodywork cart complete with locker, folding table, etc.. It's a work in progress but already holds a bunch of sanders, hammers/dollies, a stud gun, and other assorted goodies. The locker still needs painted red to match the door which is being stored inside the house.
I've also got a file cabinet that came to me brown with no top. Naturally, I covered it in gloss black after priming it. I also welded on some supports underneath, new casters, tack welded the skin to the inner structure, and sealed all the seams with mastic caulking to eliminate rattles. It was $1.25/ tube so why not? The butcher block top is still being cut to size and the drawers need painted red, but this will hold hammers and serve as a rolling base for my anvil, bench grinder, and metal chop saw- interchangeably if things go correctly.
The other thing that's been getting my attention is the cart I'm assembling to hold my pressure washer and polishers, and like the other 2 it's also still in progress. I've managed to turn an orange electric cord reel black, and it will hold the 50' of 1/4" hose that feeds the gun.
That will be mounted on the end right above the star of our show- a Bauer 2300 psi electric pressure washer with stainless quick connect fittings.
The pump is sitting atop the rest of this piece of scrap aluminum I picked up at work.
I still need to change a few things around and am waiting on a couple of parts but it's not a bad start.
Grabbed my resident set of Mouse Ears and then proceeded to crack the drain valve on the compressor in order to purge the tank of any moisture that had accumulated since yesterday. Normally I don't leave it pressurized because the local humidity is brutal; my air motor was actually Cold to the touch while I was chasing welds yesterday and the finger sander had moisture resident in its personal in line water trap. I usually have to take that trap apart at least once a week to clean and dry it out. Toopk the additional minute or two to open the drain on the primary water trap and drain that too. Come calendar fall I will have to tear it completely down and see how back the rusticles and barnacles inside have become.
Once the compressor had finished its repressurization cycle, I grabbed one of my long tube blower guns and did an air sweep of the floor to move all the dust out the door and back into the environment. Being the length that it is, I can do this job while standing up instead of having to crouch or do the kneecap shuffle. it and its associate are tools that I custom made so that I could infiltrate frame rails and hollow spaces to clean them or dry them out.
Got the floor "clean" although the broom might dispute that assertion if it had a voice and a say in the matter. I will still have to replace the wheels on my mechanics seat as over time debris has ground its way into their rolling surfaces so that the seat won't move anywhere near as freely as it used to. Did try to debride the wheel faces of metal shards and weld spatter but it really wasn't all that successful. The new wheels came in for today so tomorrow may be a shop tool maintenance day.
The passenger's door is back on the installation cradle but that will be an exercise for, again tomorrow, with possibly a few pics of the antics involved. Did end the day by completely re-draining the compressor tank, water trap, and lines. It will sit empty over night as it is once more getting cold in the evenings and I try not to leave an air charge in the tank because, as it chills down over night, the water in the air will tend to condense out and fall to the bottom of the tank. No air pre-empts that possibility and makes the compressor a happy camper.
Reactions: Sweet_Johnny
So, Sunday being supposedly a day of rest and meditation, The subject that I chose to ponder on was "Inventory". Specifically, locating and identifying various parts and components that had come into the shop and for what they were supposed to be. Once upon a 4 speed saga, I had purchased a large tote box and when the Muncie was finished and installed the box became a catch can for almost everything that made an appearance for one project or another. So it needed to be emptied and all the contents inspected and identified. Stuff that was in boxes and cartons had the contents written down on the box panels so that whatever it was could be identified without having to dump the box. Loose bits and pieces got remanded to boxes that already held similar items. Once that had all been finished, the emplty tote box became the new passenger in my Monte Carlo and all the Monte Parts and components, in their boxes and cartons, went back into the tote.
With the tote sorted and stowed, that gave me room on the shelf that I had added to my transmission cart so I retrieved the brake drums and shoes, as well as the filter and oil change, for my S-10, and set all of them on that shelf so that I wouldn't have to go on a "where da **** did I put those........******** parts chase. Once that job is done, the cart shelf will then be free to be storage shelf for another tote of body work materials.
No, the new wheels did not get attached to the mechanic's chair. They did get as far as actually sitting there in their boxes on the chair seat but no farther. Tomorrow.
Sunday Supper was Pot Roast hot and juicy and tender, with lettuce and pickles as sides and fresh dinner rolls for some carbs, all washed down with lemon Tea.
Tomorrow is a write-off for chasing parts and getting errands accomplished so more Inventory time, or not. Hot enough and the Adirondack chair will be getting a work out as I chose to do nothing.
Someone has seriously misled you by suggesting that there is such a thing as a "great Canadian philosopher-poet". While Philosopher-Poets do/did exist; have not heard of one worth any major discussion recently. And there are definitely Born in Canada Canadians although our numbers are getting fewer and fewer as our immigrant count rises and rises. But to combine both concepts in one phrase is pure oxymoronity.
Oh yeah, and if you are attempting to classify Geddy Lee of Rush as a "philosopher-poet", well first I suppose we can call him a "pee-pee" for short and, as far as the lyric abstract that you cited, I honestly cannot testify as to whether Lee came up with it on his own or borrowed it; a lot of that happens in the music industry, and the practice goes back to the pie-annie playes and organ grinders of the renaissance era.. Last Canadian I might accept as a philosopher-poet; Marshall McLuan. After that, crickets.😴 As for Rush in general. the only reason they ever got any air time up here is that the federal government passed a law makingt it mandatory for radio media to provide canadian singers and musicians with air time for their output. Translation: drivel begets drivel.
(Side bar here. Back in their bar hopping days, Rush did a gig in a local dive that I happened to frequent from time to time. Little known fact about bars and drinking establishments up here is that until the 70's, they were segregated, not by race, but by sex. As seen from above, the bars were shaped like "H"s. One leg of the H was for single men, the other was for ladies and escorts. Never the twain shall meet. If you came to a bar by yourself and expected to be able to approach a young woman and ask for a dance, about the only thing that would approach would be the bouncer to invite you to leave RFN.)
So in comes Rush, into this particular dive bar, which like others in the city, had been built to conform to the law by being shaped like an H, and they set up on the bandstand which is in the middle overlooking the dance floor. The roadie doing the sound sets up the speakers and splits them equally between both sides of the bar. The musicians turn up the volume to 11 and start torturing their instruments, and suddenly, instead of stereo, there is mono, one set of speakers has gone quiet. Roadie comes over, repairs the damage, the band??? tries again and the same thing happens.......... for the whole night. Band leader finally complains to the bar manager who comes over to the table that just happens to be situated under that stack of speakers and has a quick chat with the occupants, most of whom were very well known to me. Topic, Why? Too Loud. Band wants Loud to be heard, We can't hear ourselves Too loud, don't want loud. Bar owner is unhappy, bouncers raise hands in Uh-uh, none of our business mode; they know the occupants of that table all too well-even drink with them from time to time, bar owner makes consistent income from us coming in and drinking, band doesn't drink, doesn't play music well either....................... Bar manager gives up, goes behind bar, pours himself a double, and tells the band they are on their own. Think the roadie finally shifted all the bias to the set of speakers over on the ladies and escorts side,but that band "Rush" never played that bar here again. Absolutely no national presence or status, until a law says so. They are one of the very few bands for which I will actually stop what I am doing, if they happen to come on the radio, and turn the sound system OFF. Given a choice between them and silence, I'll take the silence.
While I don't consider Rush or any member to be prophetic I am a minor fan- I played drums in my younger days so I thought pretty highly of the Professor for a bit.
That's some interesting info about the layout of the bar- I never knew they segregated them like that. It makes sense in one way but is counterintuitive in others. And you certainly have a story that not too many people can tell, even if it's not a fond one for ya.
