Greetings Mr. Digimurda & all; I haven't fooled around with an electric Q-jet & it's been years (1986) since I've seen mine (a 1979 unit), it's in a box. But if memory serves, you'll find a plunger (piston) & spring controlling your main jet metering rods. And the spring is controlled by vacuum, & that is one factor that makes Q-jets more complexed to tune. If you change any thing that affects the vacuum signal you'll have to change the spring, rods & or jets. And the secondary jets also have rods controlled by the air valve (flapper). And the flapper is controlled by the spring & set screw at the end of the shaft. Also the secondary rod hanger comes into the equation. Hence all these adjustments make the Q-jet a fine fuel metering unit, but damn hard for the shade tree mechanic to tune. One of the many reasons so many of us hot rod type guys run a Holley, their easy. I personally have three books devoted to Holley's & I can actually carry on a conversation about Holley's & you won't think I'm a fool. So I'll bow out now & leave this thread to the Q-jet guys as I'm in over my head. Bob Jr.
