What is the cheapest possible ls swap?
Dinosport
557
146
Ct
Why not wait till you have the money available for the swap you want. If you grab a engine that takes all your money and that engine turns out to be junk what do you do then?
I agree. I havent started a build to find myself out of budget and have the car sit forever till I can get back to it. If it runs drive it. You wont break any speed records but you can enjoy the car as is until your ready. You can though grab the motor and take your time gathering parts little by little as the budget allows. it could be easier on the wallet that way as long as you have a place to store everything.
87National
663
690
eastern SD
This should give you a ball park of what the swap could cost:
http://www.hotrod.com/articles/hrdp-1103-small-block-or-ls-engine-install/
5.3L SWAP WITH CARB
Used 5.3L engine with front drives and accessories $180
S&P motor mount adapter plates $100
GTO oil pan, pickup, and windage tray $100
TrailBlazer V8 exhaust manifolds $125
Comp Cams Mutha Thumpr cam $400
Comp Cams beehive springs and retainers $315
GM single-plane carb intake $380
Holley 750-cfm vacuum-secondary carb $270
MSD coil pack control box $310
14-inch open-element air cleaner $25
GM 4L80E flexplate, spacer, and bolts $200
TH350 detent cable and bracket $45
Holley “blue” electric fuel pump and regulator kit $132
TOTAL $2,582
5.3L/4L60E SWAP WITH EFI
Used 5.3L engine with front drives and accessories plus 4L60E trans $1820
Comp Cams XFI cam $400
Used ECU $100
Reflash ECU $300
Used drive-by-wire pedal and solenoid $150
Used MAF meter and air cleaner $100
30 lb/hr fuel injectors (set of 8) $250
4L60E early Nova trans crossmember $175
Shorten driveshaft (Wenco) $75
Rock Valley EFI-style stamped-steel fuel tank and electric pump $725
Abbott Cable-X box $325
Miscellaneous wiring and plumbing $300
TOTAL $4,520
^ The OP asked for the cheapest solution, it can be done much cheaper than what you've listed.
UNGN
3,048
3,264
Southlake, TX
You pay an extra $100 for the "2 year warranty" and you bring the junk motor back and swap it for another one you find in the lot.
People actually do this in Dallas. I've seen it. I didn't believe it, but I saw it.
20,397
I wouldn't think they'd be in business for long with that kind of warranty....
87National
663
690
eastern SD
Although we are missing details on your car, transmission, etc....... if I were in your shoes, here is what I would do:
Rework your own harness and get a mail order tune. You should be able to get a conservative tune with VATS removed for under $200.
Get the ebay ls/sbc motor mount adapters for around $30.
For the fuel system, get a GN fuel sender, walbro fuel pump, and pushlock fuel line and fittings. fuel system should be around $300 total.
Elongate the T/C holes on the 5.3/4.8 flexplate and get the $25 ls flexplate spacer/adapter. A th350/th400/200r4 torque converter will bolt up.
Stock f-body ls1 exhaust manifolds will clear the gbody frame. Should be able to find a pair for around $30-40.
The gm muscle car oil pan is the most cost effective pan on the market at around $150.
Of course you will still need misc hoses, wires, fluids, relays....etc. much of it can be sourced at the salvage yard.
The key to keeping it cheap us to get a complete pullout with wiring harness, accesories, maf sensor, all bolts, etc.
DoubleV
2,154
406
83
Medina Ohio
I feel for the op being 'stuck' with a 403....
20,397
As far as a cheap swap you won't know how cheap or expensive it was until the car is back on the road.
oldsmobile joe
2,067
3,053
mpls
i don't understand? i thought gto oil pans were front sump pans. and our cars need a rear sump pan.
