Wheel Fitment Guide
kanek4
20
buzz77 said:
Kanek with a 7 inch wheel and a 3.75 backspace you can pretty much fit any 14" sized passenger car tire on the market. Since most 14 inch wheels are 6 inches wide most tire companies stop at a 225 wheel; as that is maximum recommended width by the manufacturers. The widest tire that I know made for a 14 inch rim is the bf Goofrich radial T/A 245/60/14.
Thanks bud. Actually just found a set of 15x7's I may be picking up in which case I'd probably go 235/65/15 all the way around.. correct me if that that sounds like I'd be running into a problem. Thanks for the info, great thread!
The motor for the 67 isn't getting done anytime soon, so I figured I'd run the tires instead of letting them dry rot in the garage....
4" B.S. wheels with .25" Baer billet spacers, 275/60-15s on 15x8s rear, and 225/60-15s on 15x7s front. The rears rub a little on extreme, weird, off camber stuff (in and out of my driveway), but otherwise fine.
williamattop
455
53
Appleton WI
Paint matched 18X8.5 on all four corners.
4.5 backspace and -6 offset on all four corners.
245/40 fronts
275/40 rears
Stock suspension for now. No issues
I wanted to get the wheels on first, then decide how much drop is wanted/needed.
gdouaire
626
439
Québec City, Québec CANADA
Very interesting thread!
Posted this somewhere else, but here I go:
15×8 Pontiac Rallys.
Front: 205/75R15
Rear: 225/75R15
Some rubbing in the front at full lock.
almack01
5
kanek4
20
Okay guys, I picked up a set of 14x7 ss2's for my '88 Cutlass and put them on last night. The rears seem to be fine but the inside lip of the rims in the front were rubbing against the control arm very badly. I have no idea about backspacing or offset as this is my first time experimenting with new wheels, but I'm pretty sure I need a 3/8 or 7/16 spacer to fix the problem. Any other suggestions? Thanks.
Thiessen1978
20
Lethbidge, AB, Canada
Looking at chrome reverse that is 3.75" in the fronts and 4.5" backspacing in the rear I believe. Will these fit or do they need spacers? Tires I currently have on are P195/70R14 up front and 205/75R15 in the rears.
garvir
26
on my 88 monte i used bassett imca wheels 15x8 with 4" back set, required a 1/4" spacer to give me a 1/2" between frame and tire, running 295/50r15 mickey thompson tires. rolled the fenders, that is a tough job with there being the wheel well welded to quarter. going to try 3" lowering springs to bring back down, 3" seem like a lot, but those are original springs so they probably have a 1" of sag after 25 years.. 225/50r15 will bring the front down about 2" ....use this car for road racing, what a ball.
gary
Jan 25, 2015
What is widest that I can go on a stock 79 MC? I wanna do a staggered set up with the boss 338 wheels. 18x8 in the front and 20x10 in the back. Will that fit without any issues. Scrub?thanks in advance.
Flyers9928
597
1,515
South Central Pa
OK I have 15x8 wheels with 4 1/2 to 5 inch back spacing. I was gonna run 215/70/15 all the way around but they look small. Can I get away with 255/60/15 in the rear and a 235/70/15 front? its a daily driver and any thoughts or suggestions are appreciated
