I gave you bad info there^^^. Iron Cast Knight is right. The WC started around '88 in the Fbodys.DRIVEN said:Those were all non-WC transmissions.
DRIVEN said:The earlier Fbodys were canted. The bellhousing was drilled so that the transmission would lean toward the driver. I think that it was mainly to position the shifter closer to the driver. The mounting pad for the transmission mount was also at an angle. You could use these transmissions on a "regular" bellhousing and just shim under one side of the mount. Make sense? Those were all non-WC transmissions -- if that matters to you at all.
DRIVEN said:I keep seeing on this forum and even in magazines how LSs are so cheap and plentiful. I know that my local regular wrecking yards have them, at a premium price. I've never ever seen one in a PickNPull and when they do (rarely) show up on CL they are 2K and up. I can't argue with the factory power numbers and the potential, but I think they are one of the least visually appealing engines ever made in stock form. It takes quite a bit of extra money to make one look pretty in an otherwise nice engine bay. Maybe that's the tradeoff for having plentiful rust free cars in my part of the world -- less availability of LS engine donors.
...Just my unsolicited view. Tangent concluded.
In that case I wonder if I can get away with using a V6 Camaro bellhousing if I need a BOP pattern. (Just as an example) I don't know much about bellhousings yet. Do they have different external dimensions in almost every application? For instance, if I tried using a BOP or Chevy bellhousing from a '70s car like a 4th gen Cutlass or a '75 Nova, would the transmission end up in a different location than it would with a G-Body bellhousing?86judge said:With you going a hydraulic clutch you are not limited to the specific bellhousing for 78 79 g bodys(the chevy one was hard to find, i couldn't imagine trying to find one with the olds bolt pattern)That shouldnt affedt you.
It's the same where I live. I've only found them on eBay for around 4k.Clone TIE Pilot said:DRIVEN said:I keep seeing on this forum and even in magazines how LSs are so cheap and plentiful. I know that my local regular wrecking yards have them, at a premium price. I've never ever seen one in a PickNPull and when they do (rarely) show up on CL they are 2K and up. I can't argue with the factory power numbers and the potential, but I think they are one of the least visually appealing engines ever made in stock form. It takes quite a bit of extra money to make one look pretty in an otherwise nice engine bay. Maybe that's the tradeoff for having plentiful rust free cars in my part of the world -- less availability of LS engine donors.
I have to agree with you on this. I live in NJ and everyone wants top prices for junkyard LS motors with no guarantees on them. Then in the catalogs and online I see LS parts prices are 3 times more than similar parts for SBCs which is why I strach my head when I hear how cheap LS motors supposedly are.
It's the same where I live. I've only found them on eBay for around 4k.[/quote]Clone TIE Pilot said:DRIVEN said:I keep seeing on this forum and even in magazines how LSs are so cheap and plentiful. I know that my local regular wrecking yards have them, at a premium price. I've never ever seen one in a PickNPull and when they do (rarely) show up on CL they are 2K and up. I can't argue with the factory power numbers and the potential, but I think they are one of the least visually appealing engines ever made in stock form. It takes quite a bit of extra money to make one look pretty in an otherwise nice engine bay. Maybe that's the tradeoff for having plentiful rust free cars in my part of the world -- less availability of LS engine donors.
