Why is there a ground strap on the heater core?
HAFROD
2,179
3,331
Claremore, OKLAHOMA
I'm in process of cleaning up and refurbing my 78 Salons heater box assembly. I'm replacing the heater core with a new one. I don't understand why there is a ground strap from the heater core to the firewall. Does it need to be there? I smoothed my firewall and really don't want a ground strap protruding out the front of the heater box. :wtf:
FE3X CLONE
2,714
47
48
Ohio
It's there to help fight electrolysis in the cooling system. Without it you can get a lot more corrosion between the dissimilar metals in the engine.
ssn696
Living in the Past
5,551
6,692
Permanent Temporary
The brass heater core is suspended in a plastic/foam surround and is connected to the iron engine block by rubber heater hoses - the ground strap is the only metallic connection. Dissolved minerals will make a weak electrolyte out of the coolant. Maybe you could power a dash LED off the combination.
9,619
12,706
I would just make or buy a longer ground strap and ground it someplace that is hidden if that is your concern.
jacobdavis1979
700
14
Not sure dont remember my malibu having one. The only ground i can think of back there is the head to firewall ground.
But function is better than appearance probly best to keep it
