And besides everyone knows the truth....
Your 3800 is great until it isn't...
and then it is spectacular!
Some of us still cruise these "EV's" & may have more than a person should own.I owned electric cars before electric cars were cool. They had drive by wire already, with brand names like Aurora and Tyco. And had slots in the "roads" to keep them stable. 🙂
I found the same in every truck I drove with the 5.3 and even one 6L. I found the Gen 5 8 spd was massively better. Again, if I would have been impressed and probably drove a 4th Gen Firebird, GTO or G8 like I almost bought, I might have LS fever as well. The Olds V8's, not even the 455's, the SBO, I have a stupid, feel good underdog sentiment about them. They were even dead reliable while SBC's were flattening cams and 351/400M's were knocking down the road in 70's. We owned the other makes from that time period and worked on others, not good.I think you guys’ goals are a little too low - a 4.8 in a van or pickup is a pig. And the factory cam and rpm range created by it makes it even worse. Maybe if it would’ve been offered in a lightweight car I’d have a different opinion, but in a 4000-8000 application it flat out sucks in stock form.
I think you guys should aim higher
Ah, but .... how much does that pull out of the battery how fast, and how long does it take to put that back into the battery? And what does this mean for the Texas power grid? Not to mention the lifespan of the battery, which is large and heavy and expensive and liquid-cooled.How about 920 ft lbs at 1 rpm? That's what one of the Tesla's put out....
I respectfully disagree, the 6.0 and 6.2 flat out haul *ss in a truck IMHO. The 5.3 is a happy medium between the 4.8 and 6._ and all 3, 5.3, 6.0, 6.2, can tow respectfully.I found the same in every truck I drove with the 5.3 and even one 6L. I found the Gen 5 8 spd was massively better. Again, if I would have been impressed and probably drove a 4th Gen Firebird, GTO or G8 like I almost bought, I might have LS fever as well.
The LS engine, IMO, has replaced the old school SBC. If anyone has owned a GM made in the last 20 years, likely nearly everyone had one at some point in their lives, they ended up in all sorts of engine swaps, and "relatively" cheap to build. As motorheadmike said, your ROI is pretty high by going with an LS. Simple mods recovers the choked off power and can save potential oiling and timing chain issues. However, the TTY left some letters off to describe the fasteners...shiTTY. I totally get the idea behind it, but man up and say what the bolt torque should be and rebuilding it would be even cheaper if you didn't have to replace the bolts. Torque angle gages be damned. I think that TTY was an evil money-grab plan by the bolt manufacturers...Hey, pass me another 2 sets of those 17800568 head bolts for $70!!! 😉 Some people recommend for low HP and stock rebuilds, go ahead and re-use your old TTY bolts. Seriously.
