I'm hoping to get the truck back on the road in the next couple of days so I can start saving up to fix the Monte Carlo. I miss it so much!
I miss my 94 Olds 350 TBI powered Chevy 4x4, the wrong truck burned. I would like to drive my 2000 Dodge Dakota off a cliff. I spent 2 grand on Ram EQ heads and swapped all the trans sensors and tested every sensor short of O2 sensors and a compression test. Betting both will test fine, cylinders looked fine and oil pressure is very good. I can't get the truck to link to my scan tool now. It has a bad miss and is down on power. It now runs worse than the original V6 and has about the same power. A least it isn't blowing coolant out the rad cap or into the oil anymore. Yeah, the 5.9 is such an easy swap.
If I were you I would consider adding some STP, Lucas, or some other additive to the rear diff lube to give it a little extra help.
I know that year trucks did have clutch type limited slip rears, my old '89 2WD long bed has a 3.42 posi. I would guess they can be found in many a 4x4 Suburban or Tahoe. Surely, working at a salvage yard you know all the codes to look at for gear ratio and posi trac on the build sheet/decal.
Like G80 or G81
And whatever gear ratio you need?
As far as I know, GM only used one kind of locker in the 10 bolt rear ends. The Eaton Locker (RPO G80).
that is the gov lok that you blew up and is famous for exploding
Exactly. Have you ever heard of another kind in these trucks?
