check the price of the pinion gears, new pinion shaft and thrust washers. They shouldn't be too expensive and easy to change
I am pretty sure you mean price spider gears...
the spider gears are made up of 2 pinion gears and 2 side gears. The pinions are first to go cause they are smaller than the side gear. Damage to the pinion gears is caused by the rear wheel turning different speeds dues to unequal tire size or different tire pressures. With the pinon gears constantly spinning on the pinion shaft they will eventually wear down the shaft causing the spider gears not to mesh properly. The side gears sit on the spline in the axles and are beefier than the pinion gears so they usually don't get damaged.
your rear end confirms the nic name those rear ends have...gov lok exploder
When you get it back together you might want to just baby it. She looks pretty tired (sway backed) but my dad taught me that if you baby something like that you can work it for a long, long time.
If you're referring to the sag where the cab and bed meet, that's a body mount issue. The frame is a little rusty but solid. As far as babying it, I've never been good at babying vehicles. As long as my name is on the title I'm gonna drive the hell out of it. Lol. What I will do in the future is refrain from doing 6000 RPM neutral drops on textured concrete. That's what broke this rear end. Was it stupid, yeah. Did I learn from it, most definitely. If I'm driving someone else's vehicle, I do my best to respect them and treat their vehicle with respect but if it's mine, you never know what kind of abuse it's gonna see.
