5+ years as a daily update
20,391
Thanks Mr. motorheadmike . That's very nice work.
Which brings me to a question I have. I'll use the 5660 front spring for example...This spring uses a squared end and a tangential end. Which end is up(pocket end)and which is down(control arm). I am pretty sure it's the tangential end that is trimmed. What effect would having both ends tangential? I have a feeling some people just cut and stuff with little thought to this...Maybe not. Just curious.
On the rear spring pontiacgp uses open top spring 5661 which is a squared end. When cut, it becomes a tangential end. Does this matter? I guess using the isolator corrects the possible issue if any.
I cut the bottom end
oranGekrate
199
109
Fredericksburg, VA
Thanks for the Moog link, Mike.
I bookmarked it for future reference. That is one of the best Moog spring links that I've ever seen.
Charlie, you're going to OD on information. :)
I have a tendency to over think most things to the point of info OD:unsure:
Square end goes up into the frame pocket, tangential down into the LCA notch. Trim the tangential end. If both ends are tangential you end up with a spring that is difficult to seat squarely. You can use isolators which will return the spring to "square"; I did this with the Matrix springs in my wagon using Trailblazer strut isolators.
I strongly recommend you go with at least the 5662s... especially if you have an iron block and heads. The 5660s with my all-aluminum LS1 are not up to the task.
oranGekrate
199
109
Fredericksburg, VA
Thanks for the answers on the springs... I'll definitely consider those springs. If I find those springs to be too harsh, instead of changing the springs out, I'll find a pontiac 455 and shove that in to compensate.:D
